WF2, M220I have two components in a family table generic that won't obey the table rules (I seem to have some Pro|E rebellion of late). It's not explicitly listed in the table, which means it should be included in all instances unless a parent is excluded. It has only 1 parent and that component is in the family table, being excluded from all but one instance. In that single instance, however, these rogue components refuse to show up.Ironically, I assembled them originally in this one instance, which did add them to the table. I removed them from the table and sometime after that they stopped showing up. I tried forcing a regen via the model player in the generic and the instance as well as re-assembling in the generic. The components still won't show in the instance.How do I troubleshoot this?Doug SchaeferThis thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
LinkedIn
