Display Header in 2D Paginated Repeat Region
jdanner
It would be helpful to have the option to add a "Header" row to paginated sections of a 2D Repeat Region Table.  For Example, if I have a screw with 300 family table entries, and I create a 2D repeat region in the drawing, the first table section will have the driving parameters (part no., length, dia, etc..), but once I paginate the table, that first row doesn't copy over.  If you have multiple sheets with this table, you always have to refer back to the page where the table starts.
Ideally, my thought is just a yes or no question when paginating.  Do you want to use a "header" row? Yes? or No?
Jason,
In the TBL PAGIN menu manager, there is a command to "Add Title" in which adds the header from the parent 2D Repeat Region.  This function has been available since WF3 that I know of.
Kevin Brandt
jdanner
(To:jdanner)
Kevin,
  Unless I'm doing it wrong, I don't believe it works for 2D regions.  I get the following message "Cannot add header/footer to 2D repeat region" when I attempt this command.
