Display Sheetmetal information
mhucik
Hi all,
How can i use displaying of sheetmetal information. I am in sheetmetal mode but this feature is not accessable.
Michal
7 REPLIES 7
StephenW
(To:mhucik)
The formatting on that ICON is bad. Use the model information and it gives you the sheetmetal information.
mhucik
(To:StephenW)
Hi Stephen,
Thank you for you reply, I know about model information, but i need to know about sheetmetal information.
But one more time thank you very much.
BenLoosli
(To:mhucik)
What kind of information are you looking for? Blank size? Bend angles? flange lengths?
Also, what version of Creo are you using?
Hi Ben,
I would like to see all bends in model. Not just non 90 degree walls and bends
tgriffin
(To:mhucik)
Change the config option info_output_format to text.  Then you'll be able to select bend reports, radii reports, or design check.
mhucik
(To:tgriffin)
Hi Tyler
Thank you for reply, yes it works. Maybe you know some config option to show not just non 90 degree walls and bends. Now it show me just non 90 degree bends.
tgriffin
(To:mhucik)
You could go to Bends>Bend Order to create a bend table, so that you could see all the bends.
