Does Creo 3.0 Cad Collaboration Extension supports Solidworks 2017? Can we export Creo 3.0 files to Solidworks 2017??
svaidya
3-Newcomer
Hi all
I have Creo Cad Collaboration Extension for Solidworks. I tried saving Creo .prt file as Solidworks .sldprt but did not work.
Can we save creo 3.0 file as solidworks 2017 using Cad colleberation Extension.
Sanket
StephenW
(To:svaidya)
Solved: Re: Creo to Solidworks - PTC Community
Should be as easy as file - save as if you have the collaboration extension.
Verify that the session of Creo you are running has the extension active by going to FILE - HELP - SYSTEM INFORMATION and verify the extension is active for the current session.
Creo does not save solidworks parts as the 2017 version, it saves them as the 2005 version of solidworks. Creo can open up to solidworks 2015 files.
