Hello
Need to change my 10 year old Lenovo Thinkpad T450s running windows 10 to a new one Lenovo Thinkpad P14s G5 running windows 11 with AMD Ryzen 7 Pro 8840HS CPU and AMD Radeon 780M graphics.
Would that be possible for Creo 4 M080 to run?
BR
Patrick
Officially, NO.
Article - CS348041 - Compatibility of Creo Parametric with Microsoft Windows 11
You can try and you may be lucky.
Officially, NO.
This will definitely not be supported under Win 11 and current HW as Creo 4 has been long out of support. It is possible and IMO likely that Creo 4 will run but you will have to try it and see.
Your listed HW config is ISV certified by Lenovo for Creo 11.
I believe Creo 4.0 could run on your new Thinkpad even if PTC does not support such combination.
I guess installation was successful and Creo 4.0 does not start. Is it true?
Question: Is your license locked or floating?
Possible problem sources:
1.] graphic card drivers
... try adding graphics win32_gdi option into config.pro
2.] network card
... what network cards are installed in your new Thinkpad?
... couple of days ago I met following situation:
