Draft to sketch?
davehaigh
Draft to sketch?
I have a top view of a component, that I want to show in a P&ID drawing. All I want is a 2D sketch since everything else is 2D.
I opened up the part, made a drawing with the top view I want, and converted the view to draft entities. I can select the sketch mode in the drawing and copy the draft entities, but can't seem to use them in a sketch for curves in a part.
Is there a way to do this?
What I want to end up with is a set of parametric curve entities that I can manipulate as needed.
I'd rather not do this as draft entities in a drawing.
This is what the item looks like.
[cid:image001.png@01CF7E3C.37CDDE90]
I know it's simple enough to sketch, but I was hoping for an easier method.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
davehaigh
(To:davehaigh)
Thanks to Neal Hanratty for reminding me of a trick I used to use.
Export the drawing to DFX. Then import into the sketch.
You do that now with this button in the sketcher.
[cid:image002.png@01CF7E3F.20AE3180]
It came in at the wrong scale, I just selected all the dims, picked this [cid:image003.png@01CF7E3F.20AE3180]
Locked scale and then changed one of the dims to the proper length.
[cid:image004.png@01CF7E3F.20AE3180]
David Haigh
davehaigh
(To:davehaigh)
I was just playing around with this again to see where I went wrong with the scale.
By default it came in at less than 1 to 1. Changeing the number in the scale box to 1 fixes the problem.
I had to delete the format lines.
[cid:image001.png@01CF7E40.A327E060]
David Haigh
