Drawing BOM modifications (relation issue)
jraska
I am currently struggling/fighting with modifying a drawing BOM. Something that is normally an easy task.
I am trying to accomplish two things. First swap out a couple part names. Second modify a part quantity.
When I create a relation to swap out part name that has worked for me in the past and as recent as yesterday. It does one of two things. Either carries the part number that I just renamed up through the rest of the BOM part number column. Or completely removes all TXT from that same part number column and may may blank out additional columns as well.
What am I doing wrong?
This is the relation as I am using it:
if asm_mbr_name=="7082105_50_8_MM"
prtnum="7082105"
qty1="5"
else
prtnum=asm_mbr_name
ENDIF
2 REPLIES 2
how are your tables labeled?
are they default or custom names ie for quanty -
default: rpt_qty
custom: &rpt.rel.bom_qty
example to change qty value from number to AR (as required)
code in bom table relation:
/*****QTY TO AR*****
/* ASSIGN THE MODEL NAME AND QUANTITY TO PARAMETERS
bom_qty=rpt_qty
bom_name=asm_mbr_name
/*CHANGE QUANTITY TO AR IF PART CODE INDICATES BULK ITEM
IF STRING_LENGTH(bom_name)==8
IF name_check=="119"
  bom_qty="AR"
ENDIF
/* REMEMBER TO CHANGE QUAN. in BOM Table TO
/* rpt.rel.bom_qty
/* REMEMBER TO CHANGE THE PART NUMBER in BOM table TO
/* rpt.rel.bom_name
Hope this gives some insight
ron
DonSenchuk
(To:jraska)
I'd play around with separating the prtnum from qty1. Put them into separate relations to see what you're missing.
IF asm_mbr_name == "7082105_50_8_MM"
prtnum = "7082105"
ELSE
prtnum = asm_mbr_name
ENDIF
qty1 = "5"
ELSE
qty1 = rpt_qty
ENDIF
So the first thing we see that you were missing is the 'qty1' = rpt_qty bit. Without that the repeat region doesn't know what to do in the quantity column.
Once you verify those, change your repeat region so &rpt.rel.prtnum appears in the part number column and &rpt.rel.qty1 appears in the quantity column.
(It's possible to combine them but I find if one has too many combined it's just asking for confusion.)
One other note: Something I've noticed is nearly every time a user performs copy/paste for these relations they fail. But, if they type it all out it works just fine. It might be Word causing some sort of snafu, but if you're running into trouble take the time to type it all out. I don't know why, and it's caused a lot of confusion with my users, but it does seem to make a difference. (I haven't tested with Notepad or Wordpad, so perhaps that would work ok.)
