Drawing; Delete a sheet without activating it
jchance
11-Garnet
I have a drawing with 3 sheets.  somewhere along the way the second sheet has become corrupted and the drawing will no longer publish.  i can activate/modify sheet 1 and 3 but if click on sheet 2 the program stalls and i'll have to close it out.
I'd like to just delete sheet 2 and re-create it but i don't know how to do it other than right clicking and selecting delete.  but right clicking it will navigate it to that sheet and then it'll freeze on me.
Help?
when opening the drawing use Open Representation command and select No Views representation. I hope it enables you to remove all views from Sheet 2.
Martin Hanák
Martin Hanák
we ended up sending the drawing to PTC and they found the part that was throwing the error.  I replaced the imported model with the same file used previously and it fixed the regeneration issue with that specific sheet.
That said, i did try this 'trick' after the fact and it would have worked for me.
Thanks!
