Drawing Dimension on Flat Patterns.
DB_11159812
When creating the first view of a flat pattern part, the overall (outside) dimensions and the bend angle (that’s a note, not a dim) will automatically show on the flat part.
It was working but one day stopped working.
How can I get that feature working again?
Is there a config.pro option for that?
I can still show the dims with “show model annotation” command.
Creo Parametric 8.0.2.0
Van_AG
(To:DB_11159812)
Use config option auto_show_3d_detail_items yes to auto show flat state size and bend dims.
Use config option smt_bend_notes_order to customize what shown in bend dims.
Van_AG
(To:DB_11159812)
DB_11159812
(To:Van_AG)
Looks like that did the trick. Thanks Van_AG. You are the VAN
Hi @DB_11159812,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
DB_11159812
(To:anursingh)
OK thanks. I got a reply and it worked. I thanked the person and clicked the ACCEPTED button.
