Drawing: Length of centerline shown in half section (Creo8.0.5.0)
CK_9308072
Hey everybody,
fighting with Creo Parametric on a weekly basis within our classrooms i'm slowly getting better with Creo8.
I'll take a try within this community basis: is there a config.pro-option (or elsewhere) to adjust the automatic length of the centerline within a half-section-view. "half-section-line" within "Drawing properties" does change the appearence (from solid to centerline and vice versa), but the offset length (and the adjustment) is a mystery. Where can i find the correct option within gazillion Creo-possibilities?
Looking forward 😉
Edit: yes, i tried to handle/modify it directly...
4 REPLIES 4
kdirth
(To:CK_9308072)
Try axis_line_offset in drawing DTL - File > Prepare > Drawing Properties > Options [change]
CK_9308072
(To:kdirth)
Unfortunately not; "axis-line-offset" defines the offset of model-axis. Since the shown axis is generated by the section-dialog its not affected by that option.
Top part axis trimmed by axis_line_offset, bottom part is not affected at all.
Hi @CK_9308072,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
CK_9308072
(To:Catalina)
Dear Catalina,
i WANT to close that topic; unfortunately i can't find the correct offset-option. Can you help?
