Hi all,
I am new to creo I have a query on the drawing of view. I have projected a view from a parent view and have created a lot of dimensions. Now I just want to delete the parent view or make the projected view as a parent. Is there a way to do this? This is because if I delete the parent view then the projected view also gets deleted along with it.
Thank you so much for your help in advance.
Select the projected view, right mouse click and edit the properties of the view, in the view type category, change Projection to General.
That "disconnects" the view from it's parent.
Thank you so much for reply.
Thank you so much it worked.
