Drawing Program for CREO Parametric_Beginner level
Eduardo_T
3-Newcomer
Good day folks,
This is Edward,
I’m working on the generation of drawings with CREO Parametric with repetitive steps. I want to automate the generation of the same and found that by using a function called "Drawing Program" I can do it. However, I am new to this topic. I would like to know where I could start, some book, video, example, etc. , which can serve as a reference for me to be able to make sketches.
Thanks in advance.
You are in the wrong forum.
PTC has two CAD systems:    Creo+ and Creo Parametric    and     Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
To move your post, click on the three vertical dots on your initial post and click on "Notify Moderator".
http://kotom.eng.free.fr
Good morning,
Thank you very much for the observation and guidance.
I will move my post.
Have a nice day 🙂
