Drawing dim lost ref & didn't turn purple
unknown1
Pro's,
We have an assembly which contains 2 sheetmetal parts. Part #1 is packaged.
Part #2 is fully constrained to part #1 The assembly drawing has a created
dimension referencing an edge on part #1 and the center of a hole on part
#2. The dimension leader line no longer lines up with the center of the hole
on part #2.
The problem dimension did not turn purple.
If either part changes the dimension updates but still does not reference
the center of the hole.
We have not been able to re-create the problem. Newly added dimensions work
100% properly.
ProE WF 1.0 M180 linked session to ilink 3.3 M021 .
0 REPLIES 0
