Drawing export to template
NG_10722318
3-Newcomer
Really simple..... or it should be .... and is very simple in every other program i have used.
I want to save the current drawing as a temple for use with other drawings.
I cant save a copy or the "default" model locks it.
Its crazy its not just a simple export option .... like all other software?
BR84
(To:NG_10722318)
for a new creo user, it may be difficult to figure out where to start.
there are layer of setting thing up in creo:
there are formats - tables, and frames that are printed on drawing
template drawing - a drawing that is empty - w/o part, that has (A4, A3, etc.) and selected format (see above), (both should match)
location of format, template drawing - should be set in your config.pro
examples:
pro_format_dir x:\lib\creo_templates\
template_drawing x:\lib\creo_templates\default.drw
template_part x:\lib\creo_templates\default.prt
template_assembly x:\lib\creo_templates\default.asm
there are many other options: materials, fonts, drawing settings, print settings, colors, etc.
prepare in one place folder structure and add it to config.pro -
there are videos that will walk you through:
https://www.youtube.com/watch?v=hoQ8rNQ8UJQ
https://www.youtube.com/watch?v=_0vj-6r0ENw
https://www.youtube.com/watch?v=JyyTCnvyx0k
For some time you will just keep adding things to your config you want to be set, till you will not have to return to it
Send our regards to the company that sold you creo with marvelous support in initial setting it up.
Hi there, do you want to set creo parametric default template as mmns and looking for the settings of how you can set your favorite template as default. then you are at right place In this video you will see 1. Setting the default template for Part 2. Setting the default template for Sheetmetal 3
In this video, I will tell you about the basic settings that we should do after installation or maybe later on. Ptc creo tutorial Creo Parametric Settings. See the whole series on PTC Creo Parametric. https://youtu.be/jZrePwmVpoI?list=PLQ68mYLOi6qXar28Y6PHJepQBO8QpI1fb Also see Creo Drawing ...
Join CDT's Ben Givehand as he discusses the following topics in Creo Parametric Administration: * Software Downloads/Licensing * Setting up Standards * Config.pro, Config.win(WF5.0) / .UI(Creo), Config.sup * Batch Scripting Ideas
