In 2000i-2, the new style of x-section creation was implemented, which uses a z-clipping plane to create the cross section view.
REFERENCE: Document - CS157231
I just noticed I had my .dtl set to "default" old_style, only took 8 years to discover this. Changing it to new_style.
1. Why would PTC, which advocates using the new_style, set the default to old_style? Should default be new_style?
Hmmm...did you try changing it to see what the difference was, if any?
Here is excerpt from the case on the difference between the two. So far no complaints from users on "new_style". I don't usually get feed back from users on stuff that works well. One note from below excerpt is that "old_style" will not get any future enhancements.
I saw that part. I was curious if you had actually seen the differences.
The following is my observation, not really an answer to your question... Not sure why PTC made the "non-preferred" old_style as the default but in general, all drawing options are specified in the drawing setup file, so even if they had changed the default to new_style, your drawing setup file would have continued to be set to old_style, unless you allow the drawing setup file to be over-written by a PTC provided drawing setup. This would then only apply to newly created drawings since the drawing setup is "set" when you create the drawing and only updates when specifically updated by the user. It's a safe-guard so your old drawings wouldn't automatically change with each new release.
