Drawings with formats ...
Sylvain
Hello !
I designed a format for my drawings. When I want to do a new drawing with the format, everything is fine.
The problem is when I close Pro Engineer, then I start it again, then I open the drawing ... the drawing is fine, but all the elements of the format are gone !
Do you have any suggestion ? I think Pro E should be able to keep the format of a drawing ...
1 REPLY 1
Under options look for "drawing_setup_file". See what the value is. If you haven't specified a specific place for your "dtl" file then when you restart this option goes back to default.
