Driving Sketch Not Updating
Chirs33
6-Contributor
Hey all, I hope I find you well on this fine Friday!
I'm working on a model which is driven by a simple sketch brought in via a copy geom. The copy geom is directly below the coor sys in the feature tree and I bring the driving sketch into session before opening my model. Problem is, for some reason the sketch that the model is bringing in via the copy geom is not updating. I have to edit the copy geom, apply changes and then the sketch will update. FYI the copy geom is set to automatic update in the options.
Any help greatly appreciated.
3 REPLIES 3
KenFarley
(To:Chirs33)
From the description of External Copy Geometry:
"An independent external Copy Geometry feature remains frozen in its original state, whether or not its external reference model is in session and its geometry has been updated."
This *seems* to imply that the part that was copied from can be modified, but it's not reflected in the part that is copied to. Seems odd - why keep a link between the two if they're not going to update?
pausob
(To:Chirs33)
As another poster suggested, maybe the copy geom feature has been made "independent".  Examine your model and see if this option is unchecked:
Chirs33
6-Contributor
(To:pausob)
Thank you for the replies. Please see below for what I see when I edit the copy geom. I don't have the same options as shown in your screenshot. FYI we are running Creo 4 M080.
When I right click on the copy geom and check out the feature information, I can see that the feature externally references the correct file. Dependency is set to automatic update.
