Dual Dimension Displacing Suffix in Dimension Text
Novus_Tom
3-Visitor
Hey,
I'm trying to find a way to keep a reference dimensions looking like (3.20) instead of (3.20    ) when I use dual dimensions. The only fix I've found so far is to manually override the dimension, but that's a pretty terrible solution. There should exist a way to prevent this formatting error through the software setting.
Photo attached below to show what I'm talking about.
Any advice on this is welcome!
TomU
(To:Novus_Tom)
Novus_Tom
3-Visitor
(To:TomU)
The "Suggest an idea" button is grayed out, so I'm guessing I don't have the right license to use that feature of PTC community. However, this seems more like a bug that needs fixing than a new feature to be added.
I suggest you to report the problem to PTC Support.
From my point of view the problem is related to drawing option dual_dimension_brackets.
1.]
If drawing option dual_dimension_brackets yes is set then extra space is displayed before right parenthesis in primary value. This is because right parenthesis is placed after right bracket displayed in secondary value.
2.]
If drawing option dual_dimension_brackets no is set then brackets are not displayed in secondary value and right parenthesis is placed correctly.
Martin Hanák
