I've created a drawing of an assembly that contains metric and imperial parts and I'm having trouble with dual dimensions. The metric parts all dimension as I'd expect with the metric value on top and the imperial value below. The parts created in inches display two dimensions but they end up being the same dimension. Is it possible to employ a dual dimensioning scheme on a mixed units assembly drawing and have the dimensions display correctly? Thanks in advance.
