Andy,
You have it backwards. You would expect to see higher stresses in the dynamic time results. Think about it. When time is introduced into the analysis, you are including things like velocity and acceleration. An object being quickly hit a force, pressure or otherwise, it will travel further than if it would with an equivalent static load. The displacement would be higher and, whence the stresses (directly related to displacements) would be higher.
Definitely not a primer, but best I can do in a paragraph.
Randy Speed, Principal
Speed Consulting, LLC
2871 Howard Road
Waxahachie, TX 75165
(972) 938-0490 ph (972) 937-2319 fax
www.speedconsulting.com
