EXPORT ANNOTATE ON STEP AS NOTE
Luca_Carraro
I want ro read onto step file the annotation make in a part as dimension, tollerance and note.
How to export, in a step file, annotate as note?
@Luca_Carraro wrote:
Hi Martin,
I had already tried this. But it is correct that when you import the step file the annotations become symbols?
What I want to do is to have in the step file, physically, only the value and position of the notes, not all the points of the text transformed onto line.
See "#NNN = ANNOTATION_PLANE" section "CARTESIAN_POINT" in the step file, just open with NOTEPAD.
Many thanks for your time.
Greetings Luca.
it looks like Creo exports annotations as graphical representations. See https://www.ptc.com/en/support/article/CS193762 document.
I suggest you contact PTC Support and ask them the same question.
Martin Hanák
3 REPLIES 3
maybe video available in https://community.ptc.com/t5/3D-Part-Assembly-Design/STEP-file-does-not-contain-annotations-that-exist-in-Creo/m-p/786255 discussion explains you what to do.
Martin Hanák
Hi Martin,
Greetings Luca.
Hi Martin,
Greetings Luca.
Martin Hanák
