Edge & Shade Quality
ptc-50033
2-Explorer
Does anyone know if there's a part specific option or setting that affects the quality of the edge lines & shading? I have two similar sized small simple cylindrical parts (Ø8), in the same session of Pro/E, one has round edges where you'd expect them, the other part is very faceted. Changing the Edge Quality in the Model Display dialogue box makes very little difference to the one with round edges but a big improvement to the faceted part. Just wondered if anyone had come across this and if there is a setting that I’ve never come across in the last 14 yrs of using Pro/E!!!
Ian
WF4 M160 Win XP64
4 REPLIES 4
View>display settings>model display
Then Click on the shade tab and then change the quality number (10 is best, but takes some processing power). I created a mapkey to do this if you want me to send it to you...
Tony
Ian,
Set the config option for: edge_display_quality very_high
This will clear up most of your issues, after which you can play with the
option Tony mentioned to improve shade reflections and appearance.
The options for this config are: low, medium (default), high and very_high.
P.S. btw performance and appearance does seem much better in Creo 2.
Tim McLellan
Mobius Innovation and Development, Inc.
RandyJones
20-Turquoise
(To:ptc-50033)
On 06/21/12 10:52, Ian Kimberley wrote:
> Dear All,
> lines & shading?
config.pro options that you can use to set your default different than the ootb default:
and
shade_quality
> there is a setting that I've never come across in the last 14 yrs of using Pro/E!!!
> Thanks,
> Ian
> WF4 M160 Win XP64
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
All,
Turns out to be Part Accuracy. The round one was using Relative Accuracy & the faceted one Absolute Accuracy. Changing this to Relativegave an immediate improvement. Also changing it to a smaller absolute value improved it.
Ian
