Edges displaying when they aren't really there
JustinSauber
I have created a slot on the end of the part.
When making the detail drawing a line shows up across the slot that makes it look as if the slot is only partially throught the part.
Has anyone seen this and found a soltion?
Unit accuracy is set to .0001
Wildfire 4.0 M220
3 REPLIES 3
Hello Justin,
Please try changing the drawing option "hlr_for_threads" to "no"
Update the sheets after changing the drawing option. Thanks!
Shiva
The other possible option is make the Slot feature come first and then the Hole feature.
Shiva
Shiva,
Thanks for the assist. Changing the order in the model tree solved my problem.
