Edit Definition does not work in a Pattern within an Assembly
Greg_H
11-Garnet
Just wondering if anyone else has run into this?
Typically I can change the constraints of a component in a pattern by clicking on the Edit Definition of the 1st instance.  I have one assembly where if I click on the Edit Definition of such a component, nothing happens.  If I delete the pattern, the Edit Definition works fine.  The only explanation I could find online was to check the read only under operations, but there is none.
Weird, right?
Mahesh_Sharma
22-Sapphire I
(To:Greg_H)
Hi @Greg_H
By any chance, is that component is in a group? If yes, ungrouping the pattern may allow redefine.
Will it be possible to share same data?
Thanks.
5 REPLIES 5
Mahesh_Sharma
22-Sapphire I
(To:Greg_H)
Hi @Greg_H
Thanks.
Wow, yep, that worked (better than deleting the pattern).  Wonder why though?
Patriot_1776
(To:Greg_H)
Because the redefine probably won't work 2 layers down thru the pattern and then into the group.  I agree, it SHOULD work, but...
There a lot of that in CREO I've noticed 😞
One of my favorites is functionality that is turned off because an assembly is in exploded mode. Like, you can't replace components. Never understood that one.
