Editing All Sets in a Feature (Round/Chamfer)
msteis
There has got to be a way to do this... I'd like to edit the dimension of all the sets in a feature at once such as a round or chamfer. Is there a way to do it without having to highlight each set and changing each of them?
Matt
Drive them with parameters maybe?
TomD.inPDX
(To:msteis)
The idea is that you put as many on a single set as possible.
Unfortunately, it is all to easy to forget using the CTRL key to do this.
You might try the Edit from the model tree.
But the answer is no, you have to address each set individually.
