Effect of rounding of decimal places to part
jnanesh.sajjan
Hi gurus,
The requirement of this situation is very peculiar and annoying. But there is no other way for me, I need to check and do!
I have a part with drawing.The part is constructed to 4 decimal places. But while showing the dimensions in the drawing, I should show only 2 decimal places.
(Whenever I set the decimal place in the drawing to 2, it automatically updates the part. Which I dont want to happen)
Any quick and possible reply is very much appreciated.
Thanks and regards,
KS Jnanesha
1 REPLY 1
The theory here is that the rounding changes the spec. of the part,
which it does.
Example, you design to 1/8" (0.125"). If shown at 3 places, it may take
a tolerance of +/-0.005 for a range of 0.12-0.13. If you round to two
places, not only does the nominal change to 0.13", the tolerance loosens
up to +/-0.01. The bottom of the range remains the same at 0.12, but
the upper limit increases to 0.14.
LinkedIn
