I'm a solidworks convert, and is used to drawing a sketch and then making a feature(extrude, revolve) because sometimes halfway through I decided I want to change the feature type and that's how I am used to doing this. Well, new job(mentoring engineers and draftsman) prefers to start with a feature so the used sketch doesn't show up in the model tree. Is there a way to embed the used sketch if I forget and do it the old way. I know it is possible to hide in the model tree but this is not what they want and I'm not going to argue on something like this as its a half dozen or 6 to me. Just trying to keep my self from having to remodel when I forget.
see following example.
1.] create sketch and extrude related on it, model tree contains following features
2.] edit extrude definition and click Unlink button, this action breaks relation between sketch and extrude
3.] now you can delete sketch feature
