Creo version: 8.0.8.0
Checked the article Article - CS397645 - Windchill Attribute value cannot be propagated to Creo parameter with Limited access (ptc.com) but did not get the solution.
Facing an Error "Attribute XXX cannot be propagated to yyy.prt. Modifications made to this attribute in the PDM system will be ignored.”
Article: Reported as SPR Article - CS400349 - Error Attribute XXX cannot be propagated to yyy.prt. Modifications made to this attribute in the PDM system will be ignored.” when opening inventor files in Creo Parametric (ptc.com)
