I am an engineer. The specialized field is a machine and electric design.
I suggested a patent about the hand device of the robot recently.
I want to ask an evaluation of this suggestion.
The attached files are the summary of the hand device and an animation of one finger.
Could you be the holding of such a robot hand of competition .
This is my proposal .
Material I have submitted is the first issue of the robot hand proposed .
Basis of this proposal ,
Department of Defense , such as for social reintegration has focused for the wounded in the war .
For example,
Dean L Kamen
Soldiers who've lost limbs in service face a daily struggle unimaginable to most of us. At TEDMED, Dean Kamen talks about the profound people and stories that motivated his work to give parts of their lives back with his design for a remarkable prosthetic arm.
Such activities , we are confident that 's what leads to the development and social contribution of 3DCAD.
We humbly thank you enough for your consideration .
In addition , you will attach the additional material about my proposal .@
Kenzo,
I looked at your video and PDF file, and while I'm no expert in Simulation, I'm not sure what type of information or feedback you are looking for.
Can you please elaborate a little more, so that other users who see this would have a better idea, regarding your question and could provide some useful information.
Amit
For example,
Dean L Kamen
大変遅くなり申し訳ありません。
私の提案は、ロボットの指構造に関するものであります。
その構造については、添付資料に示します。
又、提案の指の特長を誇示するために動画を添付します。
また、図面、動画だけでは、特長を表現できないものとして
追記になりますが、指の屈曲動作は、回転式であることで、挟み込みの危険がない。
構造的に、密封構造も可能となり、清潔な環境に適するものともなります
又、危険な環境下での使用も可能になります。
今一つ、屈曲動作が回転動作によるものであり、作業動作制限がないのも特徴になる可能性がある。
本件について、皆様の評価をお願いするものであります。
