Hello All,
I am trying to use the Simp Rep feature to create partial assembly stages of a complex assembly.
If there a way of hiding sub assemblies, groups or patterned items?
For example, I have a group of a nut bolt and washers, which I have patterned 6 times. At the moment it seems the only way I can hide them is by clicking each individual part and excluding them, total of 24 items. Seems a bit strange that I can't exclude the pattern ,which would hide everything, or at least on the group level, which would mean I have to exclude 6 things.
Am I missing some thing? is there a way to exlude things based on groups/pattern or sub assembly.
Thank you
Expand the groups and pattern and then use shift select to get them all. Any shown expanded parts within the groups or pattern will be excluded.
