Expanded Metal
erikleonard
Newbie
Expanded Metal
Help please. Does anyone have/know where I can get a model of expanded
metal? Any information would be greatly appeciated.
Erik Leonard
Product Design Engineer
Bush Hog, LLC
www.bushhog.com
erik.leonard@bushhog.com
Phone: 423 788 7194
Fax: 423 788 7101
RE: Expanded Metal
It's easy to make one...
Just start with a sheet of metal and pattern some cuts. If you have a large number of openings, your regen performance will be poor, so I would stop using patterned cuts and switch to either of these methods:
1) a patterned datum curve (just cosmetic, so you could adjust your material density accordingly)
2) create a surface instead of a cut, then transform it, then pattern it, then merge them, then create a cut using that surface.
3) Create a thin flat surface representing one 'cell', then pattern it, then merge them, then create a thin feature from that surface
Method #3 might be the best in this case.
Here's a good tutorial on the surface methods (2 & 3):
