Hi all,
As the subject suggests, I have a problem with the explode lines being hidden in drawing view. They can be seen as offset lines in the assembly. The only layer hidden in the drawing is 03___PRT_ALL_CURVES. When I try showing this, the hidden lines still do not show up.
Any help with this would be much appreciate. Thank you!
Hi, thanks for your speedy response!
It turns out I was not saving the status of the exploded view after adding the offset lines. Typical Creo nuances, I suppose!
What version of Creo are you using?
Not having much information to go one I can only give a couple of shots in the dark:
"nuances" that's very good! I'm gonna start using that instead of...well...you use Creo, you know.
I'm getting close to 30 years of using this software and it can still push my buttons!
