Explode Lines Hidden in Drawing View, but are Shown in Assembly
JiffiPop
Hi all,
As the subject suggests, I have a problem with the explode lines being hidden in drawing view. They can be seen as offset lines in the assembly. The only layer hidden in the drawing is 03___PRT_ALL_CURVES. When I try showing this, the hidden lines still do not show up.
Any help with this would be much appreciate. Thank you!
JiffiPop
(To:kdirth)
Hi, thanks for your speedy response!
It turns out I was not saving the status of the exploded view after adding the offset lines. Typical Creo nuances, I suppose!
kdirth
(To:JiffiPop)
What version of Creo are you using?
Not having much information to go one I can only give a couple of shots in the dark:
  • Explode Lines are tied to the explode state.  Make sure the same Explode state is selected in the drawing.
  • Are the Explode Lines on the hidden items layer?
JiffiPop
(To:kdirth)
StephenW
(To:JiffiPop)
"nuances"   that's very good!  I'm gonna start using that instead of...well...you use Creo, you know.
I'm getting close to 30 years of using this software and it can still push my buttons!
