Export Config Settings
jlippeth
Users
I would like to Export a 3D part model to 3D STEP with annotations and parameters included.
I use .hol files for holes and taped holes and would like to export the annotation associated to them.
Using the config.pro options:
intf3d_out_parameters all
intf3d_out_annotations yes
After exporting the model, I re-import it and no annotation nor parameters show up.
Also where does one config the output type AP203 or AP214?
Any suggestions?
Jeff
Jeff Lippeth ▪ Mold Design Engineer
NyproMold, Inc.
955 Tri-State Parkway, Gurnee IL 60031
144 Pleasant St, Clinton MA 01510 ▪ www.nypromold.com
50% Answered
My first attempt I did not find the config setting for Export.
But using the setting: step_export_format (type)
You can select from many versions of STEP
AP203E2 and AP214IS support Annotations and Parameters.
Using the setting: step_export_format AP203ET
I was able to export parameters with the 3D model.
I am still not able to export the hole note annotations.
Keep you posted
Jeff
NyproMold, Inc.
▪ T 847.855.2226
