How can I define the length of a flange like this in Creo? Offsetting its distance like this in SE
Create a Flat wall
Select one of the highlighted options in the 'Bend Position' tab
It doesn't let me extend the flange out, only cut it in.
Or even extend this flange to another surface rather than a dimension offset?
Hi @CB_11916535,
Anurag
