Is there a way to extend the extension line of a dimension for either a radius or a diameter?
The diameter symbol above needs to be extended similar to the diameter symbols attached as a note.
Thanks, Dale
Hold down shift while selecting and dragging it.
Just remember it is the shift key [and not the control key 🙂 🙂 🙂 ] Took me a few tries.
