External Merge & AAX
dgschaefer
Is the advanced assy extension (AAX) required to create an external merge feature?  A client without AAX can create a regular merge, but the “external” pick is grayed out.
LinkedIn
gkoch
(To:dgschaefer)
Are you in part or assembly mode? (or in an activated part or an activated subassembly in assembly mode?)
vzak
(To:dgschaefer)
Doug, yes - External Merge / Inheritance require AAX
