Hi all,
the problem is very simple to explain: if I have an assembly "A" and I do an external simplified rep "a", if I change the internal simply rep within A the external don't change (naturally I've done the Update Representation inside "a").
Even if I set the master rep in the external rep assembly, nothing happens.
Is there some "special" shrewdness?
Greetings
