External Simplified Rep
plawrence
3-Newcomer
I have created an External Simplified Rep from my assembly and created a drawing for it.  I am now trying to do the same with an opposite hand version of this assembly and I get the following message when I try to save and upload to Windchill:
"External Simplified Representation "xxx.asm" cannot be saved. ID passed in the rule is not found in the member dependency of "xxxx.asm"."
Has anyone ever dealt with this and were you successful in finding a solution?
3 REPLIES 3
Articles:
Found another solution.  I was not able to get the original way to work.
Hi @plawrence,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
