Extrusion and Measuring Tool Discrepancy (Creo 11)
JC_11865793
2-Explorer
Hello all,
I am seeing a small dimension discrepancy of about 0.01 between an extrusion (remove material) I did and the use of the measuring tool distance feature. I am scratching my head as to why, and I cannot figure out its cause. I attached some images and a video. The extruded cut is 3.00 but when I measure it becomes 2.99.
Thank you.
3 REPLIES 3
tbraxton
(To:JC_11865793)
What version of Creo are you using? Do you have absolute accuracy set in the part? It would be best for you to post your model if you are using a commercial license of the software (not many here have an academic license).  I have seen instances where Creo has small errors with the info measure tool. In your specific case I would not expect to see that error.
Try creating a measure between two points on the plane and see if it is 3 exactly, also try using a projection reference when making the measure to see if the results change.
Involute Development, LLC
Consulting Engineers
Thank you for the response. It is version 11.0.1.0 and I do have absolute accuracy set.
Unfortunately, I am working with an academic license.
I am wondering if it is a bug. I just deleted the extruded cut sketch and redid it with the same reference and dimension and now it says 3 when I measure...
