FW: Summary: Resolve mode dialog blank
dgschaefer
Answer:
I believe that this happens when you do not have right access to the
directory where the assembly or part is coming from.
I got  several quick answers  that  were right on.  Well, at least they
led me to the answer.  I have opened the assembly from a write protected
folder (which was set as my working directory) and then backed it up to
another, non-protected folder.  I had changed my working directory to
the new folder prior to backing up, but I guess Pro/E was still trying
to write the temp file to the original folder.  I closed pro/E and
restarted and the problem is fixed.
Doug Schaefer
LinkedIn
0 REPLIES 0
