Family Table BOM Balloon
Ketan_Lalcheta
I have an assembly with two instances into family table. I have generated drawing from the main file and created repeat region of Two-D type to accommodate BOM in a single table for all instances.
Issue I am facing is that even though it is a repeat region, the same table is not being recognised as repeat region when I intended to do ballooning of view using Create Balloons - All.
Requesting help on this.
I am open to share my test parts on which I am facing issue for your better understanding if required.
Thanks and Regards
Ketan
7 REPLIES 7
TomU
(To:Ketan_Lalcheta)
Ketan,
If you are willing to use the advanced editor and upload your parts and drawings, I am willing to take a look at them.
Tom
Ketan_Lalcheta
(To:TomU)
I am more interested in to do ballooning of view having family table instances. I am also not able to find how to attach parts?
TomU
(To:Ketan_Lalcheta)
When you reply to this message, choose "Use advanced editor" in the upper right corner. The advanced editor will allow you to attach files.
Ketan_Lalcheta
(To:TomU)
Please find attached model.
Regards
Ketan
TomU
(To:Ketan_Lalcheta)
Apparently you are using either an evaluation copy or a student copy, so I am unable to open them. Maybe someone else can chime in here who has one of those versions...
Ketan_Lalcheta
(To:TomU)
I will be able to provide the same without evaluation or student by mid of next week.
Thanks and Regards
Ketan
Table present into model is not been recognized as BOM table for ballooning.
Moreover, I am not able to replicate the model which I prepared into creo 3.0 trial version into creo 2.0 M090. This issue I am least interested as of now.
My main pain area is that how I am able to do ballooning using table.
Regards
Ketan
