Hello everybody,
I experienced something weird with Creo 7.0.8.0 and Windchill 12.0.2.1 :
When I save and upload a CAD, if I am quick enough to create a new part while the upload is running, Creo crashes with a fatal error.
This problem is easily reproducible (only need to be fast).
Any idea what is the cause of this issue? Is there any way to tell Creo and/or Windchill not to start a download (in this case, the startpart) while another server operation is running (in this cas uploading a CAD)
Thank you in advance
I would say this probably needs to be a tech support question instead of a community forum question.
please report the problem to PTC Support.
Thank you for your answers, I will contact my reseller to do so.
Have a nice day!
If anyone have the same issue, it was fixed in Creo 7.0.11.0 !
