Dear Experts,
Iam new to ModelCheck and I notice that the drawing is saved upon running Mcheck interactive.
Is there any way to disable this. I don't want Mcheck to save the drawing when i run Interactive Mcheck.
Another question is when Mcheck Interactive is run on a part which is in insert mode, after the check the insert mode is cancelled and all the feature are resumed.
Is this normal or is there anything i need to change to stop resuming the features?
Iam on Creo 2.0 M180.
I found the answer. I had enabled SAVE_MU. I disabled it and it worked for me.
For the second part of my question I believe that is how the MC work when MU is enable.
