All,
I have several holes in an airfoil surface. The airfoil was provided to my by a customer in STEP format. See attached JPEG.
How can I fill these holes so that the "patches" provide continuous curvature?
Maybe I should expand the holes slightly so that the holes are 4-sided. Then I can easilycreate a boundary blend with its edges with continuous curvature to the parent??? Then merge?
I do not have an ISDX license.
TIA.
Sincerely,
Neal Rosenblum
Geometrix Engineering, Inc.
201 N. 13th Avenue
Hollywood, FL 33019
Ph: 954-920-2049
Fax: 954-920-9574
Cell: 954-649-9399
neal@geometrixeng.c
As this is imported geometry, I would use Import Data Doctor functionality. It allows you to delete the holes boundaries and reveal the original surface instead.
Bjarne
In Reply to Neal Rosenblum:
All,
TIA.
Sincerely,
Neal Rosenblum
201 N. 13th Avenue
Hollywood, FL 33019
Ph: 954-920-2049
Fax: 954-920-9574
Cell: 954-649-9399
neal@geometrixeng.c
Bjarne Frandsen
(Pro/ENGINEER Wildfire 4.0 M170andWindchill 9.1M060 on Windows)
I agree with Bjarne. If the holes do not cross intersections of neighboring surfaces, you should be able to "delete" the contour that defines the hole in within the context of the import.
I was a little better at such operations in older versions of Pro/E. The "import" function in WF5.0 look more friendly and I am sure you can still do the same thing.
Neil,
sorry 'bout the late chirp, but I've found the easiest and quickest way to "fill" those holes is to eliminate the "contours" of the original surface. That is done by -Editing the definition of the feature - Geometry - Heal Geometry- Manual-Edit Boundary-Delete Contour. Select the surface and toggle 'til you find the "hole" in question and voila, its gone.
Good Luck,
Mark
Thank you to all who replied.
I was not able to find the HEAL GEOMETRY selection in the data doctor. I Googled "data doctor pro e" and found a few hits that did not seem to jive with the Wildfire 5.0 (M060) menu structure (i.e. older versions/builds of Pro|E???).
My original idea of extruding some rectagular surfaces up to the parent feature worked pretty well. I used the rectangular extruded surfaces (just a small amount larger than the oblong holes)to trim the parent surface, and then I created individual boundary blends for eachof the 4 rectangular holes with constant curvature contrainsts along each of the edges. The only think that I did not like about this solution was that it left remnants of the "patches". So when I view the airfoil in a wireframe mode, I can see the 4 rectangular patches on the airfoil. My customer questioned this as well.
The BEST solution, which I think is a takeoff of HEAL GEOMETRY, was the removal of the holes. I selected the edges of each of the 4 holes individually. While the edges were highlighted, I went to theEDIT pulldown menu and selected REMOVE. This magically removed the holes and left no remnants of the previous geometry behind. So I essentially have 4 removal features in my model tree...much better than all of the extrusions, boundary blends, merges, etc...
Sincerely,
Neal Rosenblum
201 N. 13th Avenue
Hollywood, FL 33019
Ph: 954-920-2049
Fax: 954-920-9574
Cell: 954-649-9399
neal@geometrixeng.c
