Find material ID
Marcusanthony
Find material ID
Where do I find Material ID for the materials present in material library.
I want to use relations to assign values to material parameters like density,etc.
For which I need material ID.
Method
PTC_MASS_DENSITY:MTRL_ID.
Please suggest me way to find material ID.
Thank you in advance!
aputman
(To:Marcusanthony)
Out of curiosity, what is the purpose of this?  A material library provides a list of materials for you to select from that define the properties of the part being designed, not the other way around.  This is backward thinking, in my opinion, but maybe I don't understand the application here.
Marcusanthony
(To:aputman)
I am looking to drive some dimensions based on material parameters. For this I need material ID. The following link will provide you idea how I want to derive values from material parameter
https://support.ptc.com/help/creo/creo_pma/r10.0/usascii/index.html#page/model-based_definition/example_specifying_material_param.html
BenLoosli
(To:Marcusanthony)
If you have the items defined in the material file, they are easy to pull out with relations.
Here is a sample of our Aluminum 7075-T6 material file:
ND_RelParSet_K01 = {
Name = A97075-T6
PARAMETERS =
Name = PTC_MATERIAL_DESCRIPTION
Type = String
Default = 'ALUMINUM, UNS A97075'
Access = Full
Name = PDM_NUMBER
Type = String
Default = 'UNS A97075'
Access = Full
Name = PDM_NAME
Type = String
Default = 'ALUMINUM, 7075-T6'
Access = Full
Name = DESCRIPTION1_U
Type = String
Default = 'ALUMINUM'
Access = Full
Name = DESCRIPTION2_U
Type = String
Default = '7075-T6'
Access = Full
Name = DESCRIPTION3_U
Type = String
Access = Full
Name = PTC_MASS_DENSITY
Type = Real
Default = 1.0150000e-01 lbm/in^3
Access = Full
Name = PTC_MATERIAL_TYPE
Type = Integer
Default = 9
Access = Full
Name = PTC_MATERIAL_SUB_TYPE
Type = String
Default = 'LINEAR'
Access = Locked
Name = PTC_INITIAL_BEND_Y_FACTOR
Type = Real
Default = 5.000000e-01
Access = Full
Name = PTC_BEND_TABLE
Type = String
Default = ''
Access = Full
Name = PTC_FAILURE_CRITERION_TYPE
Type = String
Default = 'NONE'
Access = Full
Name = PTC_FATIGUE_TYPE
Type = String
Default = 'NONE'
Access = Full
Name = TEMPERATURE
Type = Real
Default = 0.000000e+00 F
Access = Full
Name = DATA_SOURCE
Type = String
Default = 'MatWeb'
Access = Full
Name = VERSION
Type = String
Default = '0.1'
Access = Full
Name = CATEGORY
Type = String
Default = 'UNS Material Codes'
Access = Full
Name = COMMENT1
Type = String
Default = ''
Access = Full
Name = COMMENT2
Type = String
Default = ''
Access = Full
In our start parts we have this in the relations:
IF PTC_MATERIAL_NAME=="UNASSIGNED"
MATERIAL="UNASSIGNED"
MATERIAL_DESC1="NO MATERIAL ASSIGNED"
MATERIAL_DESC2=""
MATERIAL_DESC3=""
ELSE
MATERIAL=material_param("PDM_NAME")
MATERIAL_DESC1=material_param("DESCRIPTION1_U")
MATERIAL_DESC2=material_param("DESCRIPTION2_U")
MATERIAL_DESC3=material_param("DESCRIPTION3_U")
ENDIF
This will fill in the proper relations for what we need. You can extract any material property using the same method.
