Finding if a feature is suppressed with relations?
bentod1
1-Newbie
I don't know the best way to accomplish the following:
I have a generic part with one family table instance.
The instance only has one suppressed feature.
I want a relation that changes a dimension based on the suppression state of that feature.
If the feature (ID 318) is not suppressed, the dimension (M) = <my formula=">.
If the feature is suppressed the dimension = 0.
Here's what I tried (unsuccessfully):
IF EXISTS("fid_318")
M=.03*(tan(E/2))
ELSE
M=0
ENDIF
I would appreciate any help.
Todd
4 REPLIES 4
Did you ever find a way to do that?
In Reply to:
If the feature (ID 318) is not suppressed, the dimension (M) = .
M=.03*(tan(E/2))
ELSE
M=0
ENDIF
Todd
Todd,
Try adding the dimension "M" to your family table columns...
For the generic the value is ".03*(tan(E/2))", for the instance the
value is "0".
Good luck...
Hollie
Robert,
In reality the other-way-around is simplier and easier: Use Pro/Program
to suppress a feature if some parameter is a certain value and use the
same parameter in your family table in place of the feature. Drive the
relation for M the same way.
Here's an example assuming that you've added the parameter FEATON as
type YES/NO
RELATIONS
IF FEATON
M=.03*(tan(E/2))
ELSE
M=0
ENDIF
END RELATIONS
IF FEATON
ADD FEATURE (xxxx)
END ADD
ENDIF
Kevin
Kevin Schoonover
PTC Channel Technical Manager
Western North America
From the responses, I gather that it is not possible to determine if a feature is suppressed or unsuppressed for use in a relations conditional statement.
All the responses I saw suggested creating a parameter and putting the parameter into the family table instead of the feature. Then having pro/program do a conditional statement on the parameter to determine if the feature should be suppressed or unsuppressed.
