Flat sheet metal error when I edit dimensions of extrude
PT_8997108
Hi everyone, I don't understand this situation, I edit dimensions of extrude and flat cannot generation. Anyone can explain? Thank you so much.
@PT_8997108 wrote:
Looking forward to receiving your help. I use CREO 8.0
in Creo 8.0.4.0 I cannot reproduce your problem. I can change dimension 400 to 4000 (for example) successfully.
Maybe you Creo 8.0.0.0 contains bug - try installing newer version.
You can also try using Flange feature.l
Martin Hanák
the problem is hidden in the definition of Flat feature.
Pack the part into zip file and upload zip file. This enable community users to test your model.
Martin Hanák
PT_8997108
(To:MartinHanak)
please use zip format instead of rar.
Martin Hanák
Martin Hanák
kdirth
(To:PT_8997108)
Are you using relative accuracy?  As the size of the model increases the accuracy of the model will decrease.  At some point the features of the flat will be smaller than the accuracy of the part and it will fail.  I was able to recreate this issue in 7.0 using relative accuracy.
