Hello
I see this PTC article: CS50932
Snapshot is not updated in drawing for a flexible component
But PTC says it's article is available for: Creo Parametric 1.0 to 4.0
Anyone know if it's OK for next Creo's version ?
I have Creo 7 and obviously it does not always work
It's a problem because the PTC circumvention is not applicable (make flexible componant in 2 hard componant)
It's ok when you have not much part but it's impossible with a lot of part
I think find a way to get around the problem: but's it's not fully 🤔
In my assembly, i make all the snapshot i need.
After, i make a family table, the snapshot are inherited from master assembly
and i activate the snapshot interest me into instance.
But is not very stable when i have lot off view in my drawing.
Is it possible to call the snapshot in columns of family table.
If it is possible the probleme is then solved
I have the same request as XDN.
Is there any improvment in Creo8?
Thank you
Sorry , i don't have Creo8, i don't know if this problem as solved in 8 or 9
The content of the article raises some questions and there is a process for that: did you send an article feedback using the portlet "Something is wrong with the article" or "Was it useful"?
Here is why it is more efficient: it sends your comment directly to the authors of the article who are the better people to address the content of it.
