Flexible parameter value column in model tree
Infosys_id
7-Bedrock
need to show a column for flexible parameter value in model tree for multiple occurrences of a part in an assembly.
when i add flexible parameter to tree columns it is showing constant value for all occurrences.
Please see the attached video.
Ty
its working fine for solid components, not for bulk material component.
Based on some quick testing, I'm not sure it's possible to make bulk components flexible. Can you describe what you're trying to do with the flexibility? Maybe there's another solution to your problem.
Ty
u can create bulk material as flexible by creating a parameter in bulk material part and assign parameter type as distance measure.
PFA
